export to IFC
export to IFC
export to IFC
I have problem to Export my project to IFC file. It takes a lot of time (about 0,5h) and finally pops up error. the operation is interrupted due to some error. An unexpected error
www.TechRoom.bg
What's your Revit version and what Revit use A/S/M ?
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
Revit MEP 2015
L.Maas
You will have to do some experiments to see where the problem lies.
Exporting tends to take quite some time because a lot of conversion work has to be done.
Some things you can try:
-Try exporting a different file and see if that works.
-Change some of the IFC export options.
-There is also an (open source)  IFC exporter available which is under constant development which might improve results.
Louis
Please mention Revit version, especially when uploading Revit files.
