Even adding all available families in the library, they don't appear in the project.
lucaswillianmds
Message 1 of 37
lucaswillianmds
I have already loaded all families of ducts, pipes and disposable connections, but even so they do not appear in my project, causing me not to be able to generate a pipe in my HVAC project. Could you help me to solve this problem?
Replies (36)
Message 2 of 37
RobDraw
I think there is going to be a language barrier but I'll give it a shot.
It sounds like you are saying that you have downloaded the library. You also need to add the families to your project. Starting your project with a proper template may also help. The families should be in the project browser.
This is from a project started with the Imperial Systems project template:
Rob
Message 3 of 37
lucaswillianmds
I added all available families in the library to my project and still the connections and duct
s do not appear inside my project.
Message 4 of 37
Define Routing Preferences.
Message 5 of 37
lucaswillianmds
I've already tried to set route preferences, but no option appears, it's like there's no elbow, tee joint. Even though I carried the families.
Message 6 of 37
Do you see them in the Family Browser?  And what is going on with your posts?  Why do they appear in a scrolling window?  I can't read them on my phone.
Message 7 of 37
lucaswillianmds
This is the error that is constantly popping up. I can't set a route preference because all options are NONE.
The routing solution failed because a default connection type was not defined or the connection was not found in the project. Make sure the connection is loaded in the project and try again.
Message 8 of 37
RobDraw
Show us your project browser with the families expanded.
Better yet, share you model! You will get what you need very quickly.
Rob
Message 9 of 37
RLY_15
I believe the text boxes are an artifact of copy+pasting directly from Google Translate, I recall having a similar thing happen when trying to communicate with a Russian user earlier this week. You can use Notepad to remove any embedded formatting, or do a plaintext paste.
Message 10 of 37
lucaswillianmds
My project is too big to be shared here, it exceeds the maximum amount of MB allowed. Attached are the prints of the families loaded in my project.
Message 11 of 37
RobDraw
It looks like the families are in the project. If you loaded the entire library, you might have done too many.
What you need to do now is add them to your routing preferences.
Rob
Message 12 of 37
lucaswillianmds
The families are loaded but when I try to add them to the route preferences they don't appear, they simply remain none for all the options.
Message 13 of 37
iainsavage
You need to select each part type in turn and select a suitable family from the available options.
Message 14 of 37
lucaswillianmds
Even if I select one at a time, the families that are loaded in the project do not appear as an option for the routing preference items.
Message 15 of 37
iainsavage
Upload your model please
Message 16 of 37
RLY_15
Save-As, delete all modelled elements in the copied project file, then Purge Unused the project down to just the families relevant for mechanical/ductwork. That should get you below 20MB but still leave enough to diagnose the file.
Message 17 of 37
hmunsell
Is this only happening in this specific model or is it happening in all models you open?
Howard Munsell
Message 18 of 37
lucaswillianmds
It's only happening on this model. My model has many MB, even cleaning the project, removing unused families, I still can't load it here.
Message 19 of 37
iainsavage
This doesn't make any sense.
If you have definitely loaded the families then you should be able to see them listed in the project browser so please go to the pipe fitting or duct fitting part of the browser, expand the category and check that the families are there.
E.g.
Send us a screenshot of your version please.
Message 20 of 37
hmunsell
  • Copy your model
    • Detach from Central
  • Delete everything out of it (leave a couple pipe/Duct)
  • Remove all links
It should then be a pretty much Empty file and should be small enough to upload. if the issue still persists, upload the model. if it doesn't, then at least we have narrowed it down to something that was in your model 😊
Howard Munsell
