Revit MEP Forum
Error running heating and cooling loads
2 REPLIES 2
561 Views, 2 Replies
I have encountered a problem running heating and cooling loads on a current project. While everything appears to run normally, no report is generated at all. In the journal file, the following line appears:
' 0:< DBG_WARN: HVAC Load Calculations returned an error, error code: 105: line 6582 of Energy\EnergyAnalysisModel.cpp.
Can anyone tell me what the error code: 105 indicates? Thanks in advance for your help..
2 REPLIES 2
Chris.Aquino
To help us troubleshoot, please upload the journal file.
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
in reply to: Chris.Aquino
Here is what the journal file shows during an attempt at running load calcs...
Jrn.PushButton "Modal , Heating and Cooling Loads , Dialog_EnergyAnalysis_HeatingCoolingLoadsDlg" _
         , "Calculate, Control_EnergyAnalysis_HCLoadsRunLoads"
' 0:< Containing transaction HeatingCoolingLoadsDlg.cpp,440
' 0:< DBG_INFO: Element processing failed; subface information may be incomplete.: line 2679 of Elem\RoomGeometry3D.cpp.
' 0:< DBG_INFO: Invalid input for intersectSurfacesGivenStartPnt.: line 6841 of SurfaceUtil.cpp.
' 0:< DBG_INFO: Failed to set room bounding item and subface type for sliver space: line 852 of Elem\FixSandwichConditions.cpp.
' 0:< ::2610:: Delta VM: Avail -7 -> 8385187 MB, Used +11 -> 2268 MB, Peak +1 -> 2268 MB; RAM: Avail +0 -> 10295 MB, Used +12 -> 2368 MB, Peak +7 -> 2368 MB
' 0:< DBG_INFO: Face has no EdgeLoops.: line 1098 of FaceUtil.cpp.
' 0:< DBG_INFO: Invalid topology or geometry detected; break in geomValidateStopHere to investigate.: line 736 of GeometryUtil.cpp.
' 0:< ::2610:: Delta VM: Avail -22 -> 8385165 MB, Used +25 -> 2293 MB, Peak +25 -> 2293 MB; RAM: Avail -3 -> 10292 MB, Used +25 -> 2394 MB, Peak +25 -> 2394 MB
