I have encountered a problem running heating and cooling loads on a current project. While everything appears to run normally, no report is generated at all. In the journal file, the following line appears:
' 0:< DBG_WARN: HVAC Load Calculations returned an error, error code: 105: line 6582 of Energy\EnergyAnalysisModel.cpp.
Can anyone tell me what the error code: 105 indicates? Thanks in advance for your help..
To help us troubleshoot, please upload the journal file.
Here is what the journal file shows during an attempt at running load calcs...
Jrn.PushButton "Modal , Heating and Cooling Loads , Dialog_EnergyAnalysis_HeatingCoolingLoadsDlg" _
, "Calculate, Control_EnergyAnalysis_HCLoadsRunLoads"
' 0:< Containing transaction HeatingCoolingLoadsDlg.cpp,440
' 0:< DBG_INFO: Element processing failed; subface information may be incomplete.: line 2679 of Elem\RoomGeometry3D.cpp.
' 0:< DBG_INFO: Invalid input for intersectSurfacesGivenStartPnt.: line 6841 of SurfaceUtil.cpp.
' 0:< DBG_INFO: Failed to set room bounding item and subface type for sliver space: line 852 of Elem\FixSandwichConditions.cpp.
' 0:< ::2610:: Delta VM: Avail -7 -> 8385187 MB, Used +11 -> 2268 MB, Peak +1 -> 2268 MB; RAM: Avail +0 -> 10295 MB, Used +12 -> 2368 MB, Peak +7 -> 2368 MB
' 0:< DBG_INFO: Face has no EdgeLoops.: line 1098 of FaceUtil.cpp.
' 0:< DBG_INFO: Invalid topology or geometry detected; break in geomValidateStopHere to investigate.: line 736 of GeometryUtil.cpp.
' 0:< ::2610:: Delta VM: Avail -22 -> 8385165 MB, Used +25 -> 2293 MB, Peak +25 -> 2293 MB; RAM: Avail -3 -> 10292 MB, Used +25 -> 2394 MB, Peak +25 -> 2394 MB
