Equal angles are not equal
delie
delie
Please refer to my attached image.
LOOL, I made two angles to be equal 'EQ', LOOOL, Revit give me two different angle.
I hope my company to switch from the Stupid Revit families to other BIM software. All of us from experience of 16 years on Revit down to few months, faced 10th of illogical problems
RobDraw
It's not the software that's stupid.
Rob
iainsavage
Firstly, I don't get that result - I get equal angles
Secondly I've never yet found a need on an engineering/construction project to measure angles to hundreths or thousands of a degree.
If you think that the software is not working correctly then you should raise a support case so that the software developers can investigate it and apply a fix in future updates rather than just posting on here about "stupid software".
Nope. It works perfectly fine here.
Maybe your file is screwed or intentionally sabotaged in order to ditch Revit for another software.  Share it here if you want.
RobDraw
Reading some of your other posts reveals that you have a deep disdain for Revit. I'm with @ToanDN on his observation.
Rob
hmunsell
Can you share Your file so we can see what's going on?
Howard Munsell
