Revit MEP Forum
Element.Location to XYZ
4 REPLIES 4
5652 Views, 4 Replies
I'm trying to create a `List<XYZ>` or `XYZ[ ]` from a `List<Element>`.  Both `Location` and `XYZ` are members of the Autodesk.Revit.DB namespace, but there doesn't seem to be a conversion method.  Does anyone know of one, or have you created something that may be able to help me out?
4 REPLIES 4
fabiosato
Maybe you should try Dynamo forums?
Fábio Sato
Someone answered this for me on StackOverflow:  Location to XYZ
Also, prior to that, I was able to create this algorithm:
var fecAllElements = new FilteredElementCollector(pDoc).OfClass(typeof(FamilyInstance));
foreach (Element pElt in fecAllElements.ToList()) { lstElts.Add(pElt); }
arValvePoints = new Location[lstElts.Count];
for (itr = 0; itr < lstElts.Count; itr++) arValvePoints[itr] = lstElts[itr].Location; //PUT THEIR LOCATION(X,Y,Z) IN AN ARRAY foreach (LocationPoint loc in arValvePoints) //GET MY (X,Y,Z)s FROM THE ARRAY... { XYZ newLoc = new XYZ(); newLoc = loc.Point; lstXYZ.Add(newLoc); }
Thanks to everyone that helped, and I hope this can help someone else!!
Just saw my old code and it made me a little nauseas.  Let's maybe do this instead:
List<FamilyInstance> lElts = new FilteredElementCollector(m_pDoc).OfClass(typeof(FamilyInstance)).
Cast<FamilyInstance>().ToList(); List<XYZ> lLocations = new List<XYZ>(); foreach (var pFam in lElts) { LocationPoint pPoint = pFam.Location as LocationPoint; if (pPoint != null) lLocations.Add(pPoint.Point); }
Houba3314
hello im having a problem im trying to place family instances and if there s a familyinstance already i should skip it here is my code  even though i add the location to the list when i check if it contains the locations it s not entering a the condition
Forma Design Contest
