Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Electrical panel schedule fomat editing
7 REPLIES 7
Message 1 of 8
ananthjeyakumar31
2480 Views, 7 Replies
haii,
     how to change the revit default panel schedule format to dewa standard format please give me a solution......
7 REPLIES 7
Message 2 of 8
in reply to: ananthjeyakumar31
Manage>Panel Schedule Templates>Edit Template
I haven't the slightest idea what DEWA standard is, but once you're in the edit mode you can do whatever you want with it. Be aware, though, that there are limits to how the schedule can be organized and which parameters are available to it.
Message 3 of 8
ananthjeyakumar31
thank you,here i attached an image file ,i need an exact format like that. is there any way to edit the schedule Capture.PNG
Message 4 of 8
Pretty sure Revit won't do whatever wonky stuff you have going on there - the circuit grouping in columns 2-3 will definitely be a sticking point.
Message 5 of 8
not anymore... I think i found a solution to this... I will say its 80-90% automatic...
Message 6 of 8
axad1993
can you please share the template i really want a schedule as per dewa standard
Message 7 of 8
Ahmed.Elmahdy
Could you please advise where to start ?!
Message 8 of 8
I have the same problem ..can you help me if you get the solution?
Forma Design Contest
Technology Administrators
