Electrical Load Calculation
Binu-Kuwait
Binu-Kuwait
Can someone explain what is the difference between Electrical Settings under Load classifications the Apparent load classification method, There are 2-options in where the load is getting a change if we use the settings change either or. can anyone suggest what is the impact on this (attached image). Iam using Revit 2020
- Some True Load and reactive load (1st option)
- Some Apparent load (2nd Option)
any help is highly appreciated and Thanks for your time
Binu
Accepted solutions (3)
The True and Reactive Load (Option 1) is trying to calculate the Power without the "phantom power" given off of Capacitors and Inductors. Haven't looked into the accuracy of the algorithm given but for my firm the apparent load is more than sufficient, just enter the power and exit with the same numbers on the Panel Schedule.
Here's a link to more information from AutoDesk
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/simplecontent/content/revit...
Binu-Kuwait
Hi Tyler,
Thank you so much. appreciate for your time, Noticed there is a slight load variations if we choose the option-1 as mentioned would like to explore the algorithm given in options.
anyone else experienced this issue kindly explore
Thanks again
Guillaume.Chazal
Autodesk Support
Autodesk Support
I’m currently checking internally if we can get a document that would describe the difference between those two algorithms.
I’ll keep you informed in this thread.
Best regards
Guillaume Chazal
Binu-Kuwait
Hi Guillaume,
Thanks really appreciated
Guillaume.Chazal
Autodesk Support
Autodesk Support
Hi @Binu-Kuwait
The settings dialog actually shows examples of the different outputs each method would provide depending on the provided inputs.
For both options, inputs are Apparent Load and Power Factor
Option N° 1:
The True Load and Reactive Loads are computed then summed.
Computation details for those two values can be found on this Wikipedia page.
NOTE: Revit uses the term “True Load” instead of “Real load” as in the Wikipedia article.
From those two values, the total Apparent Load and Power Factor are computed.
In detail based on the settings dialog above:
  • Load 1
    • Apparent Load (S)= 1000VA,
    • Power Factor= 0.8
    • Trued load (P) is then equal to 0.8 x 1000 = 800.
Based on the Wikipedia article Reactive Load(Q) is equal to P x tan(arctan(Powerfactor)) = 800 x tan(arctan(0.8))= 600.
  • Load 2:
    • Power Factor= 1
    • Reactive Load is then equal to Zero.
  • Total True value = 800 + 1000 = 1800
  • Reactive Load = 600 + 0 = 600
Finally:
  • Total Apparent Load = SQRT(1800² + 600 ²) = 1897.37 VA.
  • Total Power factor = 1800 / 1897.37 = 0.9448
Option N°2:
In this case the total is computed by just summing the apparent load values (1000 + 1000 = 2000)
Then True Load values are computed and summed
From that, a power factor is computed.
  • Load 1:
    • Apparent Load = 1000
    • Power factor = 0.8
    • True Load = 1000 x 0.8 = 800.
  • Load 2
    • Power factor = 1
    • True Load = 1000.
  • Sum of Apparent loads = 2000
  • Sum of true Loads = 1800
  • Total power factor = 1800/2000 = 0.9
I hope you'll find this explanation helpful.
Best regards
Guillaume Chazal
Binu-Kuwait
Hi
Thank you so much, really appreciated for your time
Kind regards..Binu
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
