How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Can someone explain what is the difference between Electrical Settings under Load classifications the Apparent load classification method, There are 2-options in where the load is getting a change if we use the settings change either or. can anyone suggest what is the impact on this (attached image). Iam using Revit 2020
- Some True Load and reactive load (1st option)
- Some Apparent load (2nd Option)
any help is highly appreciated and Thanks for your time
Binu
The True and Reactive Load (Option 1) is trying to calculate the Power without the "phantom power" given off of Capacitors and Inductors. Haven't looked into the accuracy of the algorithm given but for my firm the apparent load is more than sufficient, just enter the power and exit with the same numbers on the Panel Schedule.
Here's a link to more information from AutoDesk
I’m currently checking internally if we can get a document that would describe the difference between those two algorithms.
I’ll keep you informed in this thread.
Best regards
Hi Guillaume,
Thanks really appreciated
Hi @Binu-Kuwait
The settings dialog actually shows examples of the different outputs each method would provide depending on the provided inputs.
For both options, inputs are Apparent Load and Power Factor
Option N° 1:
The True Load and Reactive Loads are computed then summed.
Computation details for those two values can be found on this Wikipedia page.
NOTE: Revit uses the term “True Load” instead of “Real load” as in the Wikipedia article.
From those two values, the total Apparent Load and Power Factor are computed.
In detail based on the settings dialog above:
Based on the Wikipedia article Reactive Load(Q) is equal to P x tan(arctan(Powerfactor)) = 800 x tan(arctan(0.8))= 600.
Finally:
Option N°2:
In this case the total is computed by just summing the apparent load values (1000 + 1000 = 2000)
Then True Load values are computed and summed
From that, a power factor is computed.
I hope you'll find this explanation helpful.
Best regards
How to buy
Type a product name
