I want to add a keyboard shortcut for the edit workplane -> pick a plane commands at once. I have only been able to find a way of adding a shortcut for the edit workplane command and have to manually select pick a plane from the menu. I did this via the keyboard shortcuts dialog box. I am applying it to electrical fixtures, the command is in the Modify|Electrical Fixtures tab.
Thanks!
Solved by hpoulosLS8XK. Go to Solution.
In Revit 2025 you have this optio:
I am not sure if it is what you want.
Fábio Sato
Hi, thanks for getting back to me. Unfortunately, that isn't the function I was looking for.
I thought as much. I ended up writing an AutoHotKey script to work with the keyboard shortcut for edit workplane and then automate clicking inside the dialog box instead, looks like that's the best I'll get. Thanks for your reply.
