Edit path offset for multiple circuits at once
HVAC-Novice
Advisor Advisor
HVAC-Novice
I have a project where i want to increase the default path offset for many circuits at once. I just want to grab all circuits and adjust the path offset from say 9' to 20' .
Right now I select each circuit in the system browser, and then change the pathoffset manually for each circuit individually. Selecting multiple circuits at once doesn't give me the path-offset tool or that parameter in properties.
the circuit schedule doesn't have a parameter for path offset.
Next time I can be smarter and change the default:
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Joseph_Peel
The Circuit Path Offset built in parameter is accessible in the API, so you should be able to do this with Dynamo.
hmunsell
I played around with this a little bit this morning and couldn't find a way to display that information without selecting the Edit Path button. if it can be accessed through the API as @Joseph_Peel suggests, try to write a Dynamo script to do what you need. there are all sorts of free resources out there to learn Dynamo. other option is to find a Dynamo script that either does it already, or that you can modify to make it do what you want.
Howard Munsell
HVAC-Novice
Thanks, both. I'll look into this with dynamo if it comes up again. I suspect I may be better off to choose a longer default value (20' instead of the oob 9' ) and just leave them as is even if some are " too long".
