- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So I'm having this issue specifically with TEE intersections, were they work fine will pipes that are all straight, but they don't play nicely when adding slopes to those same pipes. For example, I want a TEE intersection were the both the pipe from the right and left are draining to the TEE and then going down a pipe to the main sanitary drainage line. But when I add the slope the it basically breaks the connection with the TEE fitting.
Now this kind of stuff is done all the time in the field, but basically the only workaround I've been able to come up with is to initially draw the pipe straight out of the fitting, and then angle it up with a union fitting. Which is not at all how it would be constructed in reality, but seems to be the only work around I've managed to come up with.
Any suggestions to mitigate this problem?
