Duct Surface Pattern filter line weight
frischmann.akos
frischmann.akos
Hy,
I made a filter for one duct system to make a crosshatch pattern to the surface. (1. picture)
The pattern line weight is not thin like a normal pattern. (2. picture)
But the pattern line weight is set to 1 and the Line weights of the PEN 1 is set the minimum (3-4. picture)
If i change the PEN 4 line weight to the minimum weight the surface pattern will be good (5-6. picture)
How can i change the filter surface pattern line weight 4 to 1?
Thanks for helping!
hmunsell
take a look at this and see if it helps. its from the Arch forum, but....
https://forums.autodesk.com/t5/revit-architecture-forum/control-hatch-pattern-line-weights/td-p/7325...
Howard Munsell
frischmann.akos
Thanks, but this doesn't help of my problem.
