Duct not showing in section view
jlambert
Message 1 of 25
jlambert
So here is my problem. I am using duct to draw bus duct. When I do a section view of the run, looking at it head-on, the duct will not show. I can do no clipping and only the fittings will show and not the ductwork. Also if you put the section view at an angle then you can see it. Anyone have a solution to this.
Replies (24)
Message 21 of 25
I noticed that as well. I have never had this issue before.
Message 22 of 25
ok its the system 3200A normal busway that is causing the issue. go into the edit duct system then open the type properties at the very bottom there is a rise drop section. its currently set to none you need to set it to whatever you want the cut to look like.
Message 23 of 25
jlambert
Thanks that was it.
Message 24 of 25
RobDraw
Good catch @Anonymous!
Rob
Message 25 of 25
Please refer to the Image below. I had the similar issue to which I followed the following procedure.
Go to the respective Duct System --> Right click --> Type Properties --> RISE / DROP --> Outline
