Duct not showing in section view
jlambert
Message 1 of 25
jlambert
So here is my problem. I am using duct to draw bus duct. When I do a section view of the run, looking at it head-on, the duct will not show. I can do no clipping and only the fittings will show and not the ductwork. Also if you put the section view at an angle then you can see it. Anyone have a solution to this.
Replies (24)
Message 2 of 25
That seems odd. are ducts turned on in the vg settings? I realize you said when you set it at an angle the straight shows up but i cant imagine what else would cause it. can you get it to show up with a filter?
Message 3 of 25
jlambert
no, I have tried that I can have 2 windows up one of the floor plans and the other as the section view and I can select in floor plan and in the section view it will show that it is selected but still no geometry. And yes ducts are turned on
Message 4 of 25
is your detail level on course? another thing just to help narrow it down have you hit reveal hidden elements to see if it appears?
Message 5 of 25
jlambert
My detail is on fine and yes we hit reveal hidden and even then it wouldn't show up.
Message 6 of 25
you broke revit lol. no its probably something simple were not thinking of. have you tried turning graphics acceleration off or on, depending on where you have it now.
Message 7 of 25
jlambert
No luck there either. I had this problem yesterday and thought I might come in this morning and it would be working but nope.
Message 8 of 25
does it show up in the elevation view that is parallel to the section view you created?
Message 9 of 25
jlambert
yes, I can it only happens when you are trying to do a cut through.
Message 10 of 25
hmm, well i'll have to mess around with this some more to see if i can figure out whats goin on.
Message 11 of 25
RobDraw
Have you checked the rise/drop subcategories in the V/G overrides for the section?
Rob
Message 12 of 25
jlambert
Yes I checked that also and everything is checked
Message 13 of 25
RobDraw
How about sharing a portion of the model that is exhibiting that behavior?
Rob
Message 14 of 25
yea i'm with Rob on this one, I cant recreate this issue.
Message 15 of 25
jlambert
you mean a screenshot
Message 16 of 25
well i dont know how much a screen shot would help us but we can try it. i think Rob was wanting you to portion out the piece of the model that has this issue. that way we could load it up and see if its a view setting or a visibility setting with the duct itself or some other issue.
Message 17 of 25
jlambert
Not sure how to do this but I tried something I read.this is the first floor
Message 18 of 25
jlambert
I have attached my floor pland and circled tharea I am having issues with though it is through the hole proj
Message 19 of 25
jlambert
Sorry here is the screen shot
Message 20 of 25
jlambert
Ok so just to see what would happen I placed another busway in and I can see it but not the others still
