Revit MEP Forum
Duct & piping colour change
19 REPLIES 19
Message 1 of 20
47048 Views, 19 Replies
Dear all Friend,
how to change piping and ducting colour.
how would i go about apply colour to duct and piping everything appear in grey colour in floor plan and 3d view .please advise me which tabe can setting colour & tell us steb by step.
Tks
Raju
19 REPLIES 19
Message 2 of 20
HermanSolomon
Hi Rajre,
Would you mind answering a few questions?
1. Is the project an alteration/revamp? What is the phase of the HVAC elements and the phase of the view? If you have a look at the image I have added, the Phase for the View is set to New Construction, while the phase for my HVAC elements are set to be existing. Due to the latter, a phase filter is being applied to my 3D view, which adds a solid hatch pattern to all elements belonging to the existing phase.
2. Have the Mechanical categories been overriden (Solid grey hatch) within the view template that is applied to the 3D view?
The first option is the most likely culprit. The ducting was most likely drawn in a view which phase was set to Existing. In other words, anything you drew in that view automatically became existing items. If the HVAC services are new, you can select all HVAC elements, and in the properties panel, change the Phase to New Construction.
http://revitrecess.blogspot.com/
Message 3 of 20
www.TechRoom.bg
Hi
You can make filters for different elements (graphics overrides \ filters \ edit,new). When you have filters you can choose color and line type or solid for each filter. When you change the plan (different level or view) you can use same filters if view template is same like a previous plan (plan \ properties \ view template). If you need to set up new colors you just need to put new plan view in different template or set view template to none.
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
Message 4 of 20
in reply to: HermanSolomon
Thank you so much for your help
Message 5 of 20
Thank you so much for your help.
Message 6 of 20
jkarben
I'd recommend applying the color first at the Duct System > Graphic Override level. This will apply to all views without the need for a filter. This will free up the filter to add additional levels of control as/if needed per view.
Common practice is to apply colors via duct systems and just have one "duct" filter to apply the solid surface pattern to all the ducts.
Message 7 of 20
in reply to: jkarben
I have applied color at the Duct System > Graphic Override level. This shows Color in all the Plan / elevation / Section View but unable to see the Colour in 3D View
In 3D all the Duct are in Grey Color how can i have same System Color in 3D View ?
Message 8 of 20
jkarben
Set the 3D view's Visual Style to Hidden Line.
Message 9 of 20
setting Visual Style to Hidden shows the edges in magenta color.
I want to 3D shaded object to have magenta color.
setting the Material on system Properties level solved the Problem
Message 10 of 20
jkarben
Yep material is one way you can also add a filter to the view which adds a solid surface pattern.
Filter: Includes Categories Ducts, Duct Fittings, Duct Accessories.
Visual Style: Shaded with edges
Message 11 of 20
in reply to: www.TechRoom.bg
Hi, is there a way to apply this to ducts/equipment that are in a linked file?  I tried using the VG settings and creating a filter but it does not seem to work.
Message 12 of 20
Good morning,
what if I want to do the opposite. I don't want to show colors, and I change all type properties to NO override but I still see colors in sections (sections only) what could be wrong? I checked the Visibility Graphics and it seems nothing is wrong. I'll appreciate your help. Thanks in advance.
Message 13 of 20
fabiosato
In the Manage TAB, in Object Styles, change the color for drop and rise subcategories in cable trays, conduits, ducts and pipes categories.
Fábio Sato
Message 14 of 20
in reply to: fabiosato
Message 15 of 20
fabiosato
Nice to know!
Fábio Sato
Message 16 of 20
will.bentleySUHBB
how dose this work please ?
Message 17 of 20
fabiosato
You can check the reply or check my answer below.
Fábio Sato
Message 18 of 20
How to solve this issue if we set up with focus on using Fabrication Parts?
Message 19 of 20
fabiosato
For Fabrication Parts, use filters, you may need to create a system project parameter for these categories.
Fábio Sato
Message 20 of 20
jdepaul4GXDY
"Common practice is to apply colors via duct systems and just have one "duct" filter to apply the solid surface pattern to all the ducts."
This is some great information - can't believe it's taken me so long to learn this.. thanks
