Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Duct Accessory
1 REPLY 1
1695 Views, 1 Reply
Duct Accessory
HI,
I'm trying to create an access panel/door family for ductwork. I've tried creating a Duct accessory with a part type of 'Attaches to' from a face based family, which works in one way, but it doesn't assign the system type/name to the accessory - which is not good when you want schedules to relate to a system. Does anyone know how to create a duct attachment that will also pick up the system of the duct?
Many thanks
Regards
1 REPLY 1
CoreyDaun
I believe that in order to have your Duct Accessory inherit the System, it would have to actually be connect into it through Duct Connectors. As far as I can tell, you would have to create your family to break into the duct and replicate a section of duct within your family to fill the gap that is created.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Forma Design Contest
Technology Administrators
