Draw order / Bring to front
We just received an updated background that now grid bubbles.  The text in the grid bubbles are covering my work(light fixtures, speakers, etc.)  How do I bring my electrical items to front to be visible again?
Try setting the background to "Underlay."
I can also tell you how to get to this setting, but it depends: is this a linked background, or is it an imported AutoCAD?
It is a linked background.
RobDraw
Recommended best practice is to copy/monitor grids so that they can be controlled per view.
Rob
Agreed - This allows you to change the visibility settings of the copied grids and move the grid heads without affecting the linked background. You can change the Visibility/Graphics overrides for each View in the Properties palette for the View, or by applying a View Template.
mgoldberg98 is there somewhere i can chat with you or email you?  I need some direction with underlay and copy/monitor
Sure, you can DM me. Something I forgot to mention that might also help with your original issue - if you set the view's Discipline to Electrical it should put electrical equipment and fixtures on top of architectural elements.
