Not sure where to post this. This may or may not be a "bug" I guess, but it would be nice to have addressed either way. In REVIT 2020 & 2021 (haven't checked older versions but would guess it's the same), the "digit grouping" option seems to break customizing demand factors by load.
Our firm likes to use digit grouping for apparent power (Project Units -> Electrical -> Apparent Power -> digit grouping) to help make large values easier to read in panel schedules and other schedules. However, with digit grouping on, if trying to edit a demand factor set "by load" and you try to input a number larger than 1,000, then REVIT gives an error or wont accept the value. Anything below 999 is okay. I believe this is because the "comma" inserted by the digit grouping once you hit 1,000 changes it from number to string or something.
If anyone else comes across this, just be aware that you have to temporarily turn off digit grouping, then can input numbers larger than 1,000, and then go back and re-apply digit grouping. Once they are set, REVIT will still calc everything just fine with digit grouping, it just doesn't allow edits to the demand factors. I haven't found a different way to allow edits with digit grouping turned on.
For Autodesk - if it would be possible for digit grouping to not apply to the demand factors editing windows or otherwise allow editing large numbers in this window with digit grouping on, that would be appreciated. Thanks for your time.
