Difference between Duplicate with Detailing & Duplicate as Dependent?
Message 1 of 25
What is the difference between Duplicate with Detailing & Duplicate as Dependent?
Replies (24)
Message 21 of 25
fabiosato
Why don´t you creat it as a legend?
Then you will be able to place in multiple sheets.
Fábio Sato
Message 22 of 25
iainsavage
@micah  schrieb:
I would ideally like to have the duplicate
detail be dependent so I could edit one copy and the duplicate would
reflect those changes as well.
Once you've created your detail you can make into a group.
Editing one instance of the group will also edit all other instances.
iainsavage_0-1677525087376.pngiainsavage_1-1677525137843.pngiainsavage_2-1677525167364.png
Message 23 of 25
rmc9WR3X
One thing that is not replicated in the parent of a Dependent view (in Revit 2020) is the position of the tag for a call-out. If you move the handle in the child the handle in the parent view will not be moved.
Message 24 of 25
tbe82_theBIMengineers
Community Visitor
Community Visitor
Many a times due to dependent views, changes gets reflected in other sheets. This a major problem while doing annotation work. Is there any alternative to dependent views?
Message 25 of 25
iainsavage
Yes - Independent views.
"Many a times due to dependent views, changes gets reflected in other sheets" - that is the whole point of using dependent views.
If you've created views as dependent and then would rather have them as independent then you can change their status. https://help.autodesk.com/view/RVTLT/2024/ENU/?guid=GUID-6FB2D38A-C5D0-4660-8199-7E0057C1A5FB
