Devices missing from dependent views
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Weirdest thing I've encountered so far. I have a Communication device that appears in a parent view but not in the dependent view. I have followed the list here Missing Something in a Revit View? 33 Steps to Find Stuff | Ideate Inc but since the view that's not showing the device was copied as a dependent, all the settings are the same between the two views. This has only appeared to happen with one type of device but it's happened with every instance of that device and so far the only thing that seems to work is using Create Similar to place the same device in the dependent view and then editing it's location to match the original in the parent view. There are at least 50 of these devices and I just want to know if there's a way to fix this by view or if what I'm doing is the only way.
