DC Panelboard Schedule where ØA is Positive and ØC is Negative
afondrenUGA43
afondrenUGA43
In a real-world application, we use Sq. D I-Line Panelboards for DC circuits. We use double-pole phase A & C breakers where Phase A is positive and Phase C is negative.
I have the distribution system set up correctly showing two wires and single phase. L-L is forced to none and L-G is the potential.
In the panel type properties, Number of Phases is set to 1. The number of wires is set to 2. The number of poles is set to 1, as any other number will not allow you to select the distribution system.
How then can I show DC circuits using double-pole breakers as we actually use them?
fabiosato
It seems that only two pole system will allow you to have two pole breakers, but I understand that your situation is not very common.
Fábio Sato
