creation of local file
eng.girgis.adly
eng.girgis.adly
Good day All,
I am a student and I want to create 2 local files on the same PC as I want to try the work-sharing commands,I wish if there is a way to make that
note : I know how to create central file and local file, I just want to create the second local file on the same PC to try the work-sharing commands
chris.kershaw
Sorry but this is not possible as the local file is named after your Revit username & you cant change your username if you have a local file open.
kadmonkee
you can do this as 2 different users within the same pc
it is more work than needed
before you open your file go to options and set the user name to who you want to be at that time.
this only works if you have 2 different sessions of Revit open at 1 time
and each time you want to test something as USER 1 or USER 2 you will need to change the Revit User name.
this method is not recommended in a corporate environment.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
eng.girgis.adly
Thanks alot it exactly what I need
can I tile the 2 window of the 2 users to see them beside each others
kadmonkee
yes , if you have 2 monitors it works better
it would be tough on 1 monitor
good luck
thank you
I see that you already have your solution, but I just wanted to chime in and say that this method works fine for educational purposes.
I just did a Revit Fundamentals training class.  We didn't have network sharing set up, so I did exactly what Kadmonkee suggested: I opened two sessions of Revit, was logged into one under my Autodesk ID, and changed the name on the other.  I put both sessions side by side on my monitor, which was connected to our big screen training TV, then just switched back and forth between sessions showing how work sharing would work.  It's obviously not an ideal way to actually work on a project, but it was fine for demonstration purposes, and the students all got the gist of work sharing based on that example.
So yeah, if you're a student and only have one machine, this is a great way to test out work sharing.
