(RVT2022) I am fairly new to modeling conduit and I have a cable tray with 24 conduits side by side. The run is short, but there is a bend in the tray. I am trying to get the conduit to bend concentrically with the tray but even with using the "conduits without fittings" family its technically adding fittings so I am a bit confused. Regardless, when I use the parallel conduits command with concentric bend radius on, all the elbows still remain at the same radius. I assume that I am doing something wrong here but cant find a video or post that shows a solution
It depends on the bend family that you are using; the bend radius parameter must control the radius.
Fábio Sato
Did you click on concentric bend radius when you initiated the parallel conduit command?
It is working perfectly.
maybe you can share the model ,so we can have a look.
this image showed that it was executed correctly
I had started at the company where they had an outside party set up their model and it appears that they just had the wrong families loaded in for conduit that did not allow the radius to vary for the bends. I opened a new project and the tool worked fine. I'm just going to transfer the families in. Thanks for all your help
I'd be interested to hear how you achieve the incrementally adjusted bend radius on site; our conduit bending equipment doesn't allow for that in the UK, it's the same radius every time.
Is this a flexible product that is bent by hand?
This is the type of equipment we use:
https://www.youtube.com/watch?v=4BEN7PmumSg
https://www.youtube.com/watch?v=qDfpQsQJdog
Apologies for the basic videos!
