I have problem. I would like create a family of swich-key. I would like to istall in one element - two electrical circuit. The elemnt shoul look like that https://www.google.pl/search?biw=1707&bih=858&tbm=isch&sa=1&ei=zbqZWprtOYbbsAeumaPABA&q=wy%C5%82%C4%...
in simple like that :
https://www.google.pl/search?biw=1707&bih=858&tbm=isch&sa=1&ei=zbqZWprtOYbbsAeumaPABA&q=wy%C5%82%C4%...:
The idea is the I Would like to swich on the some sector of light using the one bottom, and when I press the second bottom the the another light could swich on. I would like to also connet this swich-key with switchgear. Then I know where is power supply.
I cab join into one element when I have lights and fire security, but when I have the 2 electrical circus then I have problem.
Please help, I neet it for now. It is really important.
Thank you in advance
Solved by robert.klempau. Go to Solution.
Hello @Anonymous,
is this what you need?
If so, you need to create an Electrical Fixture family with two SHARED nested Lighting Device families in it.
workflow:
See the family in the attachment.
Please let me know if this is what you want.
Hello
Thank you! You are awesome!!! I will follow your instructions.
I have another problem. It is the same problem like here: https://forums.autodesk.com/t5/revit-architecture-forum/parametric-array-in-x-and-y/m-p/7055964#M149...
I would like to create that: https://www.youtube.com/watch?v=HaXOytEyyWw&t=215s
Could you help me solve my revit links, because something is wrong? It doesn't work. Could we contact via email? It is faster than this forum.
Please it is so important to me. I am so close to do that.
Than you in advance.
BR
Justyna Kądziela
I tried to do the best to do someting with that, but it is more individual case, so I have to do something more that it works out.
