Creating custom tags
williams_cory_a
Message 1 of 18
williams_cory_a
I would like to create custom tags for vertical exhaust runs. I assume you create the tag and then apply it to all the runs that are the same. I need help creating those tags. I have attached a pic of the KX 3 tag and KX 4 tag
Replies (17)
Message 2 of 18
danielkazado
 First you may have a parameter for the ducts like "RiserNo" and you may load the data of 3,4 and etc to the related ducts.
 You may than duplicate an existing duct tag and in family editor you may add KX as text (if it will change for different risers this can also be a parameter). And you can add the RiserNo parameter to the tag.
So this way you can tag the vertical ducts on plan view and they will be exactly same as you shown.
I do not know how much you use tags, if you need I can help you on this if you tell the version of Revit you are using.
Hope helps...
Daniel Kazado
Please use Accept as Solution if your question is answered.
You may Give Kudos if the answer is helpful.
Message 3 of 18
danielkazado
I am also loading a sample file Revit 2014.
You will see the parameter RiserNo in Others of Duct.
 Hope helps
Daniel Kazado
Message 4 of 18
williams_cory_a
You are awesome!
Message 5 of 18
williams_cory_a
Sorry, I spoke too soon. I have revit 2016 and I am having a little trouble trying to create the parameter.
Message 6 of 18
danielkazado
You shall create a shared parameter, and call this shared parameter as project parameter Instance.
When you go to tag family editor in the list you may not see the parameter but in the lower left you can call the same shared parameter to load to tag.
You may also open Revit2014 file I send in 2016 to see maybe.
Daniel Kazado
Message 7 of 18
williams_cory_a
Any chance you can send a screencast (video)?
Message 8 of 18
danielkazado
Please find the screencast video in Revit 2016.
Daniel Kazado
Message 9 of 18
williams_cory_a
Your video is great. I am stuck on editing the tag and creating the hexagon. I have included the error message. Im having trouble figuring out why its not visible.
Message 10 of 18
danielkazado
Type VV to go to visual settings. Check in annotation tab annotations are visible, The check box up left in the tab.
Daniel Kazado
Message 11 of 18
williams_cory_a
Sorry,  one last problem.  I have done everything but when I tag the ducts the RiserNo does not show for some reason. I have created the parameter and everything.
Message 12 of 18
danielkazado
Can you please double check if you enter the RiserNo parameter value like 3 to the duct and tagging the same duct. It may be a good idea to try with a horizontal running duct first.
Daniel Kazado
Message 13 of 18
williams_cory_a
I have done this. Honestly what I did, Is I created the tag but it was tagging all the ducts because I had the ductwork tagged for sizing. Anyways, what I ended up doing was importing yours and using it to tag the duct. It worked however the riser numbers are not showing. I have entered the parameter for the vertical and horizontal duct but still no luck.
Message 14 of 18
danielkazado
Is it possible to share a part of your file including duct and tag so I may figure out the problem.
Daniel Kazado
Message 15 of 18
williams_cory_a
Of cours I will send you everything you need. What is your e-mail?
Message 16 of 18
danielkazado
Just send me a sample of the file you are using to see if I can figure out the problem.
Daniel Kazado
Message 17 of 18
danielkazado
 Can you please check the screencast below.
Daniel Kazado
Message 18 of 18
williams_cory_a
This video solves everything!
