Creating a section wont work in Floor plan
Message 1 of 9
Dear All, i have an Archi building which is linked, so now am trying to do the HVAC work.
for some reason when i click on Section and try to draw a line, it wont show up and gives me the famous error
"None of the created elements are visible in Floor Plan: Level 1 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
For example for what really irritates me:
On Ground floor the section line wont show up, it will show on the Ceiling plan and on the "ROOF [last floor plan]"
well i checked the View template : Section in annotation is checked
clicked on view hidden lines, nothing shows up
My "Ground floor" is [From down to top] is 4.6 meter
Please check the attachment image to see my "View range"
i even made the botton offset and depth 1000 just for testing.
P.S
this problem is at All the floors [Ground, First, Second] and roof there are no problems in the section element.
can anyone help me please am so tired of this
Replies (8)
Message 2 of 9
Also i want to add something i noticed [Attached image]
The building is self is SOLID
usually when i link an Archi file it comes like half tone or transparent.
could this be the problem ? and how can i fix it
Message 3 of 9
micphillips
In your floor plan view, go to your visibility settings and click the annotation tab. Verify that "sections" are checked as visible.
Message 4 of 9
Yes it is checked
first thing i checked
Message 5 of 9
fabiosato
Select your section in the project browser, check HIDE AT SCALES COARSER THAN value, the problem can be there.
Fábio Sato
Message 6 of 9
m.voss.alvine
chucky, what version are you in?  Can you make a section outside of the building?
Revit MEP 2015 Certified Professional
Revit Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional
remember to 'accept as solution' if this helped
Message 7 of 9
it is not that 😞
Message 8 of 9
We are using Revit AMS 2016
and NO, i cant make any section in the whole floor plan,
the whole building is SO WHITE, usually when i link an Archi drawing is comes like halftone, almost, but this one is different
Message 9 of 9
Hi Chunky. I suspect that the reason why the color of the archi model is halftone, is that the Discipline maybe is set to Architectural. There's a possibility that the View Template is not correct. Try go to the View Properties and change the Discipline there to Mechanical.
