Couldn't rotate after load to family
pe_simon
Message 1 of 13
pe_simon
I am crating a set of family, when i load a bushing family and want to rotate to fit the union inlet, it shown couldn't rotate to this position. Why? And how to fix it, thanks.
Replies (12)
Message 2 of 13
ennujozlagam
edit your bushing family, check in the properties if there is always vertical and untick it?
Message 3 of 13
pe_simon
done, but still can not rotate
Message 4 of 13
ennujozlagam
can share the file?
Message 5 of 13
pe_simon
Sure, thanks.
Message 6 of 13
ennujozlagam
Revit family you created is a  work plane based model you can't rotate that family? you need to create a family in a generic model based. thanks
Message 7 of 13
ennujozlagam
either you can use this and modify? thanks
Message 8 of 13
pe_simon
How to check the model is created by which based ?
Message 9 of 13
ennujozlagam
Message 10 of 13
pe_simon
I load your family in project, but also can not rotate?
Message 11 of 13
ennujozlagam
ok. just used your family and can be rotated just set your workplane first before dragging your family?
Message 12 of 13
pe_simon
Thanks, but there are in family mode, not in project mode.
Message 13 of 13
ennujozlagam
share the complete family?
