convert mep ifc to rvt
Message 1 of 10
I have recieved a ifc file with duct and pipe.
when i convert the file in revit with "open ifc" are all ducts and pipe shown but not editable as a duct or pipe.
is there another method to convert the ifc file or a dynamo program ?
Menno
Replies (9)
Message 2 of 10
mpeperkamp
Hi @Anonymous
First, I would try to retrieve the original Revit file. Then you have the opportunity to further model it.
If this is not there, there is no possibility of further modeling.
Industry Foundation Classes (IFC) is a neutral and open file format for sharing and sharing specific BIM information (model objects and their properties) between the various software applications of parties in the construction process. IFC is independent, so no one is bound to software packages. With IFC, the entire building sector, from architect to contractor and real estate manager, can communicate with the same intelligent data.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
Message 3 of 10
fabiosato
Instead of using open command, I suggest you to link it to an empty file, after the link process is finished you will find in the IFC file folder a RVT file, you can try to use that one. The link generates a better RVT model than open, I have already created an idea about it.
Create an empty file, in the application menu, under OPEN, select IFC OPTIONS, in the IMPORT IFC OPTIONS, you can map the IFC classes with Revit categories.
The easiest way is to open any of the txt files and prepare the file in the notepad or Excel, after you finish load the table.
Then use link command.
Fábio Sato
Message 4 of 10
RJK42
can you elaborate on that a little more? I understand how its create a rvt file but how can you utilize note pad or excel to produce the actual native file?
Message 5 of 10
fabiosato
Check the image below, this table is created from the file in Import IFC Class Mapping, which can be edited using notepad.
Fábio Sato
Message 6 of 10
Why not open IFC directly from the file menu?
Message 7 of 10
fabiosato
IFC 2x3, has only CABLETRAY type, so whenever you import conduits and cable trays will be set under cable tray categories, at least that was what happened in my previous experience, to separate both you need to use IFC subtype.
Fábio Sato
Message 8 of 10
RJK42
Thanks for this but will this allow me to gain control over the pipe? So that I can control the way it looks when switching between course, and fine?  Ultimately I need it to be a native revit element.
Message 9 of 10
fabiosato
From converted IFC file you have only the full geometry visible, if you change the detail level it won´t change.
At least in the test I made exporting from Revit and opening beck in Revit.
Fábio Sato
Message 10 of 10
RJK42
i do not see an option to accept as solution
