Dynamo Help
Dynamo Help
Dynamo Help
Hey everyone, I am trying to finish this script up and I need some help. The goal is to determine which spaces contain which air terminals, read the "Specified Supply Airflow" parameter from the space, and apply it evenly to all the air terminals in that space. I'm having trouble figuring out how to divide it evenly among only the ones in their respective spaces. Any help is appreciated!
L.Maas
I would make use of the archi-lab package and do something like
Louis
Please mention Revit version, especially when uploading Revit files.
That worked perfect! Thanks so much for the input!
I have another question...
I want to set flow ranges for air terminal types (i.e. 6" neck, 8" neck, 10" neck, etc.)
Then I'd like to auto select which type it should be based on the flow assigned to it by the script you helped me with. How would I accomplish that? I was thinking "if" statements.
