- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I added clearances to a ootb 208V-MCB-surface Panel. I made quite some effort to have it make code compliant electrical and work spaces and also allows me to off-center the work space etc.
Now I don't want to repeat the same task for the 480V, flush and MLO panels. That would be 16 families in total.... seems a waste of time to do the same thing 16 times. Is there a way to convert this panel to a different type? I couldn't see how it knows the voltage and the MLO/MCB difference. I assume this is hard-coded? Typically my plan is to have fewer families that can have more functions. Ideally i come up with one panel family that can include all of the above.
The electrical connector seems to have the Voltage Information. So I may be able to have a parameter to control voltage. I didn't see any sort of indication for MLO/MCB.
I think i could make the family to be both flush and surface-mount since that doesn't impact electrical calculations.
I also wonder if I could have nested panel families. To achieve the above.
I'm not an electrical engineer, and haven't really used Revit for load calcs. And I fear one of my ideas may have unintended consequences when it comes to accurate load calculations.
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
