electrical setting not visible in revit 2014
Electrical settings button not visible in revit 2014.
Kindly find attached snapshot.
Thanks in advance
J
CoreyDaun
Hello, and welcome to the Discussion Groups!
I've never heard of this problem, before. Try a reinstall (if you haven't already), and if that doesn't work, I suggest opening a Support Case, which can be done through the Subscription Center on Autodesk's main website.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
casquatch
I believe this is a factor of the settings within the User Interface section of the Options in Revit.
See screenshot, if I uncheck the Electrical Tools, I no longer see the Elec Settings on the Manage tab. Verify that you have your electrical tools turned on.
Casey
CoreyDaun
Nice - that sounds like the right answer, there. I always figured that only affected the "Systems" Tab.
casquatch
I figured it would just be the systems tab too, since it says "Systems tab: electrical tools", but I checked tried it out and everything was removed when it was unchecked (panel schedule tools, electrical settings, etc.).
One of Revit's "undocumented features" I guess.
Thanks mate, One of our it guy let me knoe st away, just logged in now.
GHASEM_ARIYANI
HI casquatch
Thanks for the good tips
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
