electrical setting not visible in revit 2014
Electrical settings button not visible in revit 2014.
Kindly find attached snapshot.
Thanks in advance
J
CoreyDaun
Hello, and welcome to the Discussion Groups!
I've never heard of this problem, before. Try a reinstall (if you haven't already), and if that doesn't work, I suggest opening a Support Case, which can be done through the Subscription Center on Autodesk's main website.
casquatch
I believe this is a factor of the settings within the User Interface section of the Options in Revit.
See screenshot, if I uncheck the Electrical Tools, I no longer see the Elec Settings on the Manage tab. Verify that you have your electrical tools turned on.
Casey
CoreyDaun
Nice - that sounds like the right answer, there. I always figured that only affected the "Systems" Tab.
casquatch
I figured it would just be the systems tab too, since it says "Systems tab: electrical tools", but I checked tried it out and everything was removed when it was unchecked (panel schedule tools, electrical settings, etc.).
One of Revit's "undocumented features" I guess.
Thanks mate, One of our it guy let me knoe st away, just logged in now.
GHASEM_ARIYANI
HI casquatch
Thanks for the good tips
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
