I'm soing some Conduit runs, an am finding I cannot change the "Angles" of my conduits...........i.e., from 22.5 degress to say 15 or 30, or anything for that matter........When I "edit Family" the Angle param is setup as an Instance param, but when loaded into the projects, and added toa conduit run, it is greyed out in the props palette.
I looked at the Lookup table, and the Properties themselves, and there are now references or formulas....
Any ideas as to how to orverride the angles?
Mike
I don't think you can change the angle from the fitting, you should just be able to drag the end of one of the conduits to the angle you want.
I agree, in the field electricians use specific angles, no one will ever bend a 27.18 degree bend. Being able to select or limit the bend angles would be a great feature addition.
