Changing MEP fittings
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I'm routing duct work sometimes i need a standard take off and sometimes I need a beveled or a beveled w/damper. Now I know how to change routing preferences and to get the fittins I want as per which duct I'm working with. What my concern is that when I try to change a standard takeoff that has already been created to a beveled takeoff I get the following warning/error, "Changing the family for a MEP fitting might cause unexpected results.". I am aware of the results that will happen when I change the fitting, it's the reason I'm changing it to begin with, I want those changes to happen to the system. Is there a way to get that warning to not come up? Right now if I want to change the take off I have to delete it, go into "edit type", change the routing preferences, and then reconnect. Then if I need to change back to standard I have to go through the same process. It's very time consuming when working with low velocity systems where I need beveled at the brach takeoff but standard at the diffuser plenum connection. I have attacked a couple screen shots of the process. Please advise.
