When trying to assign a specific system for a mechanical equipment not included in those one puposed by Revit but created in the project, duplicating an existing one and renaming, I cannot find a way to select and change the arranged by default. So for example to give a system ducts for this heat recuperator to the fresh air duct, It seems that the connector has no ways to do it, and pipe segments gives no the right results.
Could I collect any observations from you?
Thank you for your patience
Best regards
Lorenzo
that is the system classification, not the System Type.
Howard Munsell
Howard's correct - the classification is primarily used to define the airflow calculation method needed for the type of system. The "system type" is what allows you to have variations in this (Supply Air, SP Low pressure, etc.) but has to be based on the overall type of airflow being used.
The connector only needs to know which one of the classifications to use. Other Air will not calculate flow, and fitting should only be used for connectors that are "passing" flow values through another device such as an elbow, tee. These devices have their own values based on design criteria for items such as loss co-efficient.
FYI, I stay away from global - that one allows you to use any system classification based on what's set for the duct. It's rare that I would have family where I don't define the classification, since I need to keep them separate for data management purposes.
thanks - David B.
David A. Butts
Virtual Design and Construction Manager - Kimley-Horn
Revit Certified Professional/Autodesk Certified Instructor
Revit, AutoCAD Architecture, MEP, Plant 3D, BIM Collaborate Pro Subject Matter Expert
