Change Appearance of Mechanical Equipment Hidden Lines
peterson
Message 1 of 8
peterson
I would like to change the appearance of Mechanical Equipment Hidden lines on my plans. I have edited the line styles to match what I want, both in the family itself, the line styles in additional settings, and object styles, but they are still showing up black in all views. What else is there that I am missing that could be affecting the Mechanical Equipment Hidden Line Styles? I've attached screenshots of the plan view, the object styles, and the line styles for the project. The line styles in the family are also the same, but I could only upload 3 screenshots.
Replies (7)
Message 2 of 8
peterson
Screenshot of current object styles in the family.
Message 3 of 8
RSomppi
Message 4 of 8
dmiller_SCE
As @RSomppi shows in the image, the project's hidden line settings are globally controlled.  If your only objective is to change the color for the mechanical equipment and you want to have all the line work the same color, you can always create a filter for just mechanical equipment and override the color. This will force all the lines in mechanical equipment, including the hidden lines, to inherit the filter color.
Message 5 of 8
lim.wendy
Hi Gregory,
Thanks for reaching out to the forum. Have you had a chance to look over the suggestions provided by our experts?
Do you have any questions about it, let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 6 of 8
peterson
Thank you so much!
Message 7 of 8
RobDraw
Rob
Message 8 of 8
RSomppi
Welcome.
