Cannot make a central model out of existing project.
- Mute
- Permalink
- Report
Hi All,
I am trying to make a central model out of an existing project that was only used by one team member. Im in Revit 23 for reference.
When I go to the collaborate tab and enable "within your network" worksharing, it seems to be fine, it goes through the process. I then go to save as and the option "Make this a Central Model after save" is grayed out and unable to be checked. Then I look at the bottom and see I have no active workset, which to me means worksharing is not enabled. There is only two worksets, "Workset 1" and "Shared Levels and Grids". It is my understanding that these are default worksets. If I attempt to make any of the worksets "non editable" I get the error "The project has not been synchronized to Central since this workset was created. Please synchronize with central and then make this change". Which leads me to believe this is the issue.
I have no idea how my coworker set this project up initially and neither does he. To my knowledge this was never a central model, even if it was, why would there be an issue turning into to one? The option for "detatch from central model" is also grayed out. We are trying to hand this project off to our pre-fabrication team since coordination has been completed.
Has anyone experienced this or does anyone know the solution?
