HOW TO AVOID EXPLOADING THE ARROW HEAD WHILE EXPORTING REVIT SHEET INTO CAD
sabarish_a
Observer Observer
sabarish_a
Observer
Observer
HOW TO AVOID EXPLOADING THE ARROW HEAD AND ITS LEADER LINE WHILE EXPORTING REVIT SHEET INTO CAD
RSomppi
That is not possible. Revit leaders do not convert to AutoCAD leaders and vise versa.
sabarish_a
Observer
Observer
Can a plugin or an API be used to fix the issue of Revit leaders and arrowheads not converting properly when exported to AutoCAD DWG?"
RSomppi
I don't know.
RLY_15
Only method I know involves some heavy use of Dynamo to re-interpret the linework endpoints and essentially build the Revit leader off the coordinates, would not recommend unless you're talking hundreds of details with dozens of leaders due to R&D time... it will probably be better to build them from scratch (especially if your CAD explosion also converted multiline text to single-line which can happen depending on CAD formatting).
