Can't open model, stuck in loading screen.
kleinnagelvoort
kleinnagelvoort
I have an issue opening multiple models in Revit 2021.
When i try to open the "un-openable" file it gets stuck after loading in the properties and projectbrowser tab.
The famous blue circle just keeps spinning round and round for days.
I checked/unchecked all options available opening a model in every combination possible.
I also tried all the Autodesk options to restore the file etc. also without succes.
This problem only occurs when opening the file in our VDI, when i open the file locally it opens normally.
I also tried to open it locally with Audit then save it back to our VDI without succes.
Any suggestions are more then welcome 🙂
s.borello
Can you create a new local file than convert that to a new central model?  I would restart my computer and try that.
