Can't Change System Type
ben
ben
I have a mechanical piping model and a plumbing model. I need to be able to work on both of them in the same model, so I linked the plumbing model into the mech piping model, binded the link, and ungrouped it, so now essentially they are one model combined together. However, it seems like some of the system types for piping didn't transfer with it's associated piping. In the stand alone plumbing model everything is correct - domestic cold water is System Type domestic cold water, storm drain above ground is System Type storm drain above ground, where the over flow ties in, that branch is System Type overflow, where sanitary sewer transitions from sewer to vent, there is a clear switch from System Type sanitary sewer to vent. But when I link & bind the model storm sewer has a system type of undefined and when I click the drop down to menu for System Type, there are no other system type options; all the domestic water lines are now shown as domestic hot, and there is not transition from san sewer to vent, it just shows it all as sewer.
The piping system families are in the project browser. I had linked & binded these models previously with older versions of the model, and that time it worked fine, so I'm not sure why it's not working this time
Revit lives in the land of perfect and doesn't understand what construction is.
Replies (12)
simon.locke
Hi there,
If you end up with an undefined pipe or duct system for any reason, a way I find works to get a recognised system type back onto it is to add an extra piece of pipe/duct onto the undefined system. Prior to joining the new piece on, set the system type to the one you require. This should then transfer to the undefined one. You can then delete the additional piece of pipe or duct.
Hope this helps.
Simon.
BIM Consultant at Graitec Ltd
Feel free to like or accept solutions as long as it is a solution or as a minimum, useful!
ben
I tried doing that to one of my storm drains, it worked, but I lose my overflow designation on their branches & it wont let me change just those branches, it changes everything. I was hoping there would be an easier way, like just selecting the system. When I tried doing the same thing for my domestic cold, to change it from hot, but it just makes that branch line coming off it as cold
simon.locke
That's kind of the thing with Revit pipes and ducts, once they're connected they generally act as one. The other way I've used in the past which could get frowned upon is to not use Revit Link to bring in the other pipes etc... In your PH project, copy to clipboard all of the elements you want in the Mech project. Go into the mech project and go into an elevation view and use 'Paste Aligned to Picked Level' and then select the level representing the lowest copied item. This should paste all items in along with their systems as they were.
ben
For some reason when I link in the plumbing model, it still has all it's system types associated with the piping. It's just when I bind it, that's when it loses or changes the system type
I'm not sure why it worked before but wont work now
fabiosato
Whenever you bind a link, all pipe systems are not transfered and they need to be recreated again, the option would be to use Dynamo to recreate everything from the link to the host file. But I am not sure if it is possible.
Fábio Sato
suchita.kumari
Community Visitor
Community Visitor
Did you find any alternative? I am facing same issue, even after splitting pipe.  these are acting as connected system pipe. nothing works.
ben
Honestly, this was so long ago, I don't remember. Sorry
bgumPXZJF
The method in message 4 worked great. Wow. Thank you for sharing.
ahmed-fawzii
Observer
Observer
has anyone tried it with dynamo or API and worked with him ?
Ahmed_Ramy_JBI
Hi All! Any updates on the topic??
Ahmed_Ramy_JBI
I'm trying to assign piping systems using dynamo
daniem
Any Luck with dynamo?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
