can not open Revit 2016 File to revit 2018
rafilathif
rafilathif
I was work with Revit 2016 now i need to try a Revit 2018 but can not open the file. i understand some family not support but i'm ready to delete the file coming the popup dialog box no option to delete how can i open any one have a solution
dzanta
open the revit 2016 project in 2016 revit
find the family that is having an issue converting to 2018
open that family in 2018 by itself and see if you can upgrade that family first
if you can, save the family as a 2018 to reinsert into your upgraded 2016/2018 project file
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
kadmonkee
another option is when upgrading to a later version do them sequentially 2016,2017,2018 avoid skipping versions.
2016 is pretty stable
2017 has some issues
2018 has more issues
if you upgrade from 2016 t o2017 it may work better.
keep an archive of each version while upgrading.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
rafilathif
I just Delete the family and try to open the file going up to 40% progress after nothing Revit become a normal it go recent file area like below. all functions are workable i can select
and i can upgrade the family what your are looking the first family there i opened and save for 2018 but i can not open the file to upgrade.
rafilathif
I think i have to open the file to Revit 2017 after 2018.
i hope this will help
Yes , it's better up upgrade gradually.  Open 2016 file in 2017, save.  Open 2017 file in 2018.
