Can not create new filters
StigBrenden
StigBrenden
I have a big problem creating new filters in my project.
When I'm trying to creating a new filter or duplicate an old one, something strange happens.
Skjermbilde.PNGThe underlined text is my new filter, when this was created I can no longer select the other filters in my list or edit my new filter.
Has any one seen this problem before?
dzanta
the filter may be corrupt...can you delete it and recreate it?
purge command does not purge filters (fyi)
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
StigBrenden
Hi Thanks for the proposal, but this happens anyway.
When I try to create a new or duplicate filter, it appears in the list, but when I try to select it, it is not selected. It is also not possible to choose any of the other filters either. All i can do is choose cancel. Having worked with Revit for almost 6 years, this is the first time I've experienced this.
nadine_ochoa
Observer
Observer
If it lets you delete a filter do that, I ran into the same issue.  I wasn't able to create new filters or edit the existing ones but as soon as I deleted 1 rule-based filter it let me create a new one.  Not sure if its a glitch in Revit but it worked.
