Change Yes/No parameter on different Family
marco.defina
marco.defina
we have some different header that work with cold and hot, we have a parameter with Yes/No that we can change in model. It works a part from the fact that if i want to change this parameter on two different header, i can't...
There is a way to resolve? I have thousan header in the project Smiley Sad
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
L.Maas
The issue is that this is probably that this is a family parameter. While the name might be the same behind the scene Revit uses a large number (GUID) to distinguish between the different parameters. So in different families the parameters will have a different number.
Some possible solutions
1-Modify the families and make use of a shared parameter. The shared parameter will have same number in all families
2-Select headers of the same family only (e.g use filters)
3-Make use of Dynamo to automate the process.
Louis
Please mention Revit version, especially when uploading Revit files.
marco.defina
Thanks, i used the Shared parameter and I resolved!
