Revit MEP Forum
BS EN 545 Ductile Iron Fittings (Dimensions)
12 REPLIES 12
Message 1 of 13
sagnewYUXLR
612 Views, 12 Replies
sagnewYUXLR
Hi there,
When dimensioning in revit I cant seem to click a snap for some of the ductile iron fittings (tees, cross piece etc)
does anyone know why this is and what the solution is to be able to dim to ductile iron tees and cross fittings etc?
#ductileiorn #watertreatment #flange
Hi there,
12 REPLIES 12
Message 2 of 13
iainsavage
in reply to: sagnewYUXLR
iainsavage
Could you upload the family files?
Message 3 of 13
sagnewYUXLR
in reply to: iainsavage
sagnewYUXLR
Hi it's the out the box revit families
attached as requested.
Message 4 of 13
sagnewYUXLR
sagnewYUXLR
anyone help here?
anyone help here?
Message 5 of 13
iainsavage
iainsavage
Sorry I had a look earlier and can’t explain the behaviour. I compared the cross family to other fittings which allow dimensioning and I couldn’t figure out what is different in these families. @robert.klempau or @L.Maas or @fabiosato could probably help
Message 6 of 13
sagnewYUXLR
sagnewYUXLR
thanks for taking the time to look it's much appreciated.
Message 7 of 13
fabiosato
fabiosato
Please check if they are behaving as expected, I just changed the setting of some reference plane and lines from not a reference to weak reference.
Fábio Sato
Fábio Sato
Message 8 of 13
sagnewYUXLR
in reply to: fabiosato
sagnewYUXLR
Many thanks for your time effort but unfortunately this still doesnt allow me to snap to anything on the fitting when trying to dimension to it.
Message 9 of 13
fabiosato
fabiosato
In the medium or coarse detail level you can create the dimensions.
Fábio Sato
Fábio Sato
Message 10 of 13
sagnewYUXLR
sagnewYUXLR
That's not really ideal though is there a solution i can dimension in fine view ? anyone from autodesk able to tell us why their fittings don't work?
Message 11 of 13
RobDraw
RobDraw
You get the content without any guarantees expressed or implied. Autodesk is is unlikely to respond here as this is just one example of some of the shortcomings of their content. You need to fix it yourself, obtain other content more suited for your needs, or make it yourself.
Rob
Rob
Message 12 of 13
fabiosato
fabiosato
You can place the dimensions and then return the view to fine mode.
Fábio Sato
Fábio Sato
Message 13 of 13
sagnewYUXLR
sagnewYUXLR
Ok thanks much appreciated
