Hi all,
I linked an IFC into Revit, but it doesn't show the pipes. Instead, I can only see some arrows (or cones) which are the connections or ends of the pipes. See attached screenshot.
Does anyone know how what the problem is and what I should do to make the pipes visible in Revit?
Thanks in advance,
Sjors
Upload the IFC so we can have a look.
-Are the pipes actually in the IFC? Have you looked at the IFC with a viewer?
-How was the IFC made (which program).
-Have you tried differtn Revit version.
-Have you tried with another computer.
-Have you tried to link in IFC, but using clean project.
-Have you asked the source of the IFC to retry it with some different settings?
Louis
Please mention Revit version, especially when uploading Revit files.
Thanks for answering. I cannot upload the IFC file because of compliance, but:
- IFC file looks completely normal, I attached another image from Solibri
- Was modelled in Revit (But I don't have that file)
- I haven't tried another version, but it was in a clean file. I don't believe it will make a difference
Check your IFC import settings.
Fábio Sato
