Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Best way to go about making this element one family?
1 REPLY 1
m-de-lange
238 Views, 1 Reply
A colleague of mine wants the attached element in the RVT file to be one family with connectors.
I was thinking about loading each seperate family into a new family but i can't seem to connect them then.
What would be the best way on making these elements one functioning family?
1 REPLY 1
mauricio_mssf
in reply to: m-de-lange
there is no way to convert from .rvt to .rfa, neither to insert tubes and connections in a family.
You can open the .RVT and export as dwg -> .SAT file. Create a family (.RFA) and import into a inport the .SAT file.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Forma Design Contest
