Automatic pipe sizing errors
merhef.asc
merhef.asc
when, automatically,  sizing a water supply piping system with water heater in, always generate error. once the water heater is removed all are fine. any one can help
tim.ingle
Hi @merhef.asc, can you share the Water Heater family that you are working with? I believe something might be calculating incorrectly from the piping connector(s) within the Water Heater family.
merhef.asc
thank you for the follow up,
it is out of the box Revit family, I have tried more than one family  but same issue. here it is.
regards
Nathan.HilsonN67V6
Can you post a quick screencast of what it's doing? Also, what content are you drawing with, Generic revit families, Revit fab parts, or a custom content pack such as building data?
iainsavage
Edit the water heater family as follows:-
  • Create an instance flow parameter for hot water and assign it to the hot water outlet connector.
  • Create an instance flow parameter for cold water and assign it to the cold inlet connector.
  • For the cold water flow parameter insert a formula to make it equal the hot water flow parameter.
Reload the family into your project.
Flow should now pass through the water heater with the correct values.
merhef.asc
thank you, it works
