@isosa9APBT wrote:
About 35% of our projects still come in as 2D CAD files. While is not a big number, there is still big enough that we don't want to draft the building then do our design. I agree that the design is done way better in 3D. I'll bring it up to upper management, but since they are more used to AutoCAD since that's where they started and haven't learned or don't want to learn Revit, this makes it hard to translate the challenges that come with having to draft things between Revit and AutoCAD. I'm thinking about using drafting views to do both the schedules and details, it's practically 2D CAD but on Revit. Once Revit fixes the schedules then we can fully use the Revit schedules, unless there are other issues that arise from that, but so far it looks like the best option.
Revit isn't able to create a "dumb" table. And there is another idea to vote on....
A manual table in 2D view wouldn't have the ability to wrap text etc. It basically would be lines and text and if you change text, you have to change lines. Totally useless. The schedules are tables, and powerful, but only represent what is in the model. So, this is where we are.
Besides the notes on the bottom of schedules, there isn't really much to fix. The intent is to model as it is built. If you include all diffusers, they will be in the schedule automatically. once set up properly, you never want to go back. When I add an AHU, the coil water flow and pressuredrop will be added to the hydronic system, the AHU will be part of the duct calculations, and the motor will show up in the electrical panel, and all technical data will show up in the AHU schedule. And the lighting calculation will recognize the light reflecting off the AHU. and if i change the AHU, it will automatically update. People that only used AutoCAD, can't imagine what they are missing. It literally is like explaining someone in 1920 that the rotary phone will turn into a mobile device with Internet.
How do you deal with the 65% that comes as Revit? Are they truly usable and 3D? Are you using Revit fully for those? Maybe start with those?
If you can't convince your peers/managers... my best recommendation is do as much in Revit as you can and don't let others hold you back. Project by project shift more items to Revit.
Where I work, we've had 8 Revit licenses for more than the last decade. And I'm the only one using Revit......... if I waited for others to use Revit, I still would use an abacus and draw in sand 🙂
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
