Autocad DWG file import shows solid instead of hatched pattern in Revit
Message 1 of 25
I am pretty new to Revit so please bear with me if this is an easy fix. When I import any CAD file into Revit, hatching that was done as a pattern and not manually, shows up solid black. I fixed one by changing the hatching scale since I saw that in another post about the same issue, however the rest are still not right and reducing the scaling any further would not appear hatched at all. Any help would be great. Thank you in advance.
Replies (24)
Message 21 of 25
glee5P4QU
Community Visitor
Community Visitor
Maybe unrelated, but if the line weight of the hatch is the issue, could try Manage >> Object Styles >> Imported Objects and changing the line weight of the hatch's layer to something smaller. Just fixed a really annoying linked file where the heavy hatch was hiding everything and wasn't responding to any VG or overrides in view by doing this.
Message 22 of 25
I suggest you to explode your hatch in CAD Files before link / import to revit model.
One advise, Maybe you should use link CAD files to revit model instead of import CAD because when you use link CAD. You can easy control all CAD files that you link into revit model.
Message 23 of 25
bim360-7-HHA
Community Visitor
Community Visitor
Thank you Fabiosato, it worked!!!
Message 24 of 25
cameronGVZZT
Community Visitor
Community Visitor
This worked for me! Thank you!
Message 25 of 25
MaimoonaQGTXK
Observer
Observer
Thanks this worked for me
